StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,336 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Getting the car out of a winters nap. Put the battery back in the car, fired right up for me. I noticed that none of my gauges were working at all, tach, fuel, gauges in the center console aren't working either, oil press, volts. Shut the engine down, turn the key and no lights light up on the multi function gauge, oil press, Alt light.
Started the car back up it ran for a little bit and I noticed that the Alt light came on. going to check the volt. reg. I checked all the fuses and all were good. Checked to see if the belt was ok, it seemed fine. What else should I be looking for to solve this problem? |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
You have 4 small red wires that connect at the + batt post. 2 of those take 12v to the cabin and 2 go to your relay board. Check that connection as it got moved around when you re-installed the batt. (IMG:style_emoticons/default/poke.gif) How's your lungs doing?
Lo-Fi Version | Time is now: 11th July 2025 - 11:30 AM |
