Well shoot... MSD help for those "in the know", Check my work please... what am I missing? |
ThePaintedMan |
Mar 24 2014, 04:26 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Went to wire up my MSD that I purchased from Rob last year finally this past weekend.
I temporarily wired everything like the picture below shows: Unfortunately (and I guess fortunately) nothing happened. The only difference to the diagram is that I have a Compufire pointless module instead of a Pertronix. Did the troubleshooting steps by checking the wiring over several times, still would only crank but not fire. Then did the unplug ignition coil wire test, turn ignition to on, then touch white wire to ground. I did get a spark. Hooked it all up again and cranked but still no fire. MSD recommends at that point that the unit be sent back to them. Since I bought it second-hand from Rob, I'm going to assume I'm not eligible for warranty repair. So, before I do, is there any collective knowledge that could point me in the right direction? When everything is wired back the way I had it before, it starts right up, so I know the coil (Bosch blue) and module are still working. Maybe MSDs don't work with Compufires? |
jim_hoyland |
Mar 24 2014, 06:06 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Did you do the "spark" test ?
Lo-Fi Version | Time is now: 11th June 2024 - 10:37 AM |
