> Just don't have any power, Need advice as to what to check
barebrad
post Mar 23 2014, 05:14 PM
Alright everyone, I need a little help.
I have a '73 914 with a 2.0. Spent the last 7 months rebuilding the brakes, suspension, interior and painting it. PO said the engine was recently rebuilt. I haven't checked the compression yet. It has a single carb, Weber/Redline 32/36 DGEV recently rebuilt. I didn't record the jet sizes. My problem is that it just doesn't pull hard at all. Took me almost a mile to get to 45mph and 4th. At rest, when I work the throttle, it responds great and spins up to high RPM quickly. I verified that the accelerator is opening the throttle all the way. I have verified that I don't have a break/caliper that is stuck.
Not sure if it is related, but just to have the whole story, it also has issues starting. With a newly rebuilt starter, new fully charged battery and with all the ground straps removed, cleaned and tightened. It turns over for a second and then just stops, hesitates and then turns over again but very slowly. Key off/on and it does the same thing.
I know the aerodynamics are not that bad! (IMG:style_emoticons/default/evilgrin.gif) So where do I look first and then second?
Thanks.
(IMG:style_emoticons/default/sunglasses.gif)
barebrad
post Mar 25 2014, 03:07 PM
So I found the wires for cylinders #1 & 3 were reversed. Connected them correctly and adjusted the timing to 34BTDC per the Pelican Article. Now it smokes like crazy! Works well to keep the mosquito's away. It starts great too! Just a bump of the starter. Because it has been switched probably for quite some time, do I run the engine for awhile to see if it stops or is it already toast?
Thanks to all for the input so far!
barebrad   Just don't have any power   Mar 23 2014, 05:14 PM
Spoke   It has a single carb, Weber/Redline 32/36 DGEV re...   Mar 23 2014, 06:53 PM
aircooledtechguy   :agree: Those are the worst thing to ever happen...   Mar 23 2014, 07:36 PM
wndsrfr   Alright everyone, I need a little help. It turns...   Mar 23 2014, 08:11 PM
Mblizzard   Whole I agree on getting rid of the single, it sti...   Mar 24 2014, 06:18 AM
saigon71   Check your timing. Additionally, verify that your...   Mar 24 2014, 06:19 AM
Jerlle   In addition to what has been mentioned I'd che...   Mar 24 2014, 03:29 PM
barebrad   Thanks for all the advice! But I have a follow...   Mar 24 2014, 05:10 PM
Mblizzard   Thanks for all the advice! But I have a follo...   Mar 24 2014, 05:18 PM
barebrad   [quote name='barebrad' post='2015456' date='Mar 2...   Mar 24 2014, 05:30 PM
Mblizzard   I think that might be the first thing to address. ...   Mar 24 2014, 08:17 PM
Mblizzard   For some reason that drawing strikes me as wrong. ...   Mar 24 2014, 08:22 PM
ClayPerrine   For some reason that drawing strikes me as wrong....   Mar 25 2014, 06:33 AM
barebrad   So I found the wires for cylinders #1 & 3 were...   Mar 25 2014, 03:07 PM
saigon71   I believe your timing is still to advanced. On my...   Mar 25 2014, 03:19 PM
barebrad   I believe your timing is still to advanced. On m...   Mar 25 2014, 03:46 PM
Mblizzard   :agree: While that is a recommended setting for ca...   Mar 25 2014, 03:29 PM
saigon71   :agree: While that is a recommended setting for c...   Mar 25 2014, 03:40 PM
boxsterfan   I thought 27 BTDC is where your timing should be s...   Mar 25 2014, 04:17 PM
Mblizzard   I thought 27 BTDC is where your timing should be ...   Mar 25 2014, 06:09 PM
Dave_Darling   Correct for D-jet systems--and that's at ~3500...   Mar 25 2014, 10:03 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:56 AM
