> Just don't have any power, Need advice as to what to check
barebrad
post Mar 23 2014, 05:14 PM
Alright everyone, I need a little help.
I have a '73 914 with a 2.0. Spent the last 7 months rebuilding the brakes, suspension, interior and painting it. PO said the engine was recently rebuilt. I haven't checked the compression yet. It has a single carb, Weber/Redline 32/36 DGEV recently rebuilt. I didn't record the jet sizes. My problem is that it just doesn't pull hard at all. Took me almost a mile to get to 45mph and 4th. At rest, when I work the throttle, it responds great and spins up to high RPM quickly. I verified that the accelerator is opening the throttle all the way. I have verified that I don't have a break/caliper that is stuck.
Not sure if it is related, but just to have the whole story, it also has issues starting. With a newly rebuilt starter, new fully charged battery and with all the ground straps removed, cleaned and tightened. It turns over for a second and then just stops, hesitates and then turns over again but very slowly. Key off/on and it does the same thing.
I know the aerodynamics are not that bad! (IMG:style_emoticons/default/evilgrin.gif) So where do I look first and then second?
Thanks.
(IMG:style_emoticons/default/sunglasses.gif)
Mblizzard
post Mar 25 2014, 03:29 PM
(IMG:style_emoticons/default/agree.gif) While that is a recommended setting for carbs, I found that single carbs seemed to do a little better with less advance. Of course that is not saying it will make a huge difference.
I would think that there is a good build up of less than completely burned deposits in 1 and 3. I would run it a while and use a premium gas. It may clear up.
barebrad   Just don't have any power   Mar 23 2014, 05:14 PM
Spoke   It has a single carb, Weber/Redline 32/36 DGEV re...   Mar 23 2014, 06:53 PM
aircooledtechguy   :agree: Those are the worst thing to ever happen...   Mar 23 2014, 07:36 PM
wndsrfr   Alright everyone, I need a little help. It turns...   Mar 23 2014, 08:11 PM
Mblizzard   Whole I agree on getting rid of the single, it sti...   Mar 24 2014, 06:18 AM
saigon71   Check your timing. Additionally, verify that your...   Mar 24 2014, 06:19 AM
Jerlle   In addition to what has been mentioned I'd che...   Mar 24 2014, 03:29 PM
barebrad   Thanks for all the advice! But I have a follow...   Mar 24 2014, 05:10 PM
Mblizzard   Thanks for all the advice! But I have a follo...   Mar 24 2014, 05:18 PM
barebrad   [quote name='barebrad' post='2015456' date='Mar 2...   Mar 24 2014, 05:30 PM
Mblizzard   I think that might be the first thing to address. ...   Mar 24 2014, 08:17 PM
Mblizzard   For some reason that drawing strikes me as wrong. ...   Mar 24 2014, 08:22 PM
ClayPerrine   For some reason that drawing strikes me as wrong....   Mar 25 2014, 06:33 AM
barebrad   So I found the wires for cylinders #1 & 3 were...   Mar 25 2014, 03:07 PM
saigon71   I believe your timing is still to advanced. On my...   Mar 25 2014, 03:19 PM
barebrad   I believe your timing is still to advanced. On m...   Mar 25 2014, 03:46 PM
Mblizzard   :agree: While that is a recommended setting for ca...   Mar 25 2014, 03:29 PM
saigon71   :agree: While that is a recommended setting for c...   Mar 25 2014, 03:40 PM
boxsterfan   I thought 27 BTDC is where your timing should be s...   Mar 25 2014, 04:17 PM
Mblizzard   I thought 27 BTDC is where your timing should be ...   Mar 25 2014, 06:09 PM
Dave_Darling   Correct for D-jet systems--and that's at ~3500...   Mar 25 2014, 10:03 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:59 AM
