partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Not sure how to ask it, but is it possible on a ECU, like a home computer to reload the program, as sometimes solves a problem?
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
You can test most sensors before changing them. Info is available on the web. Modern ECU can act like one symptom and be a totally different problem.
I had an issue on my turbo motor that felt like a lack of fuel. Turned out to be a bad coil so the ECU cut the fuel... (IMG:style_emoticons/default/dry.gif) A new set of coils was all it took (IMG:style_emoticons/default/beer.gif) More better ones... I had a limp mode problem. tracked it down to an intermittent connection on the temp sensor. Keep looking |
Lo-Fi Version | Time is now: 20th July 2025 - 06:25 PM |
