StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,336 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Getting the car out of a winters nap. Put the battery back in the car, fired right up for me. I noticed that none of my gauges were working at all, tach, fuel, gauges in the center console aren't working either, oil press, volts. Shut the engine down, turn the key and no lights light up on the multi function gauge, oil press, Alt light.
Started the car back up it ran for a little bit and I noticed that the Alt light came on. going to check the volt. reg. I checked all the fuses and all were good. Checked to see if the belt was ok, it seemed fine. What else should I be looking for to solve this problem? |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
I would pull the tach and combo gauge and check the red/white wires for 12vdc with the ignition on.
Lo-Fi Version | Time is now: 11th July 2025 - 11:32 AM |
