EFI for 1k, programable |
r_towle |
Mar 27 2011, 03:00 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it exist yet?
Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
914forme |
Apr 3 2014, 10:59 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
CB Compitition Fuel injection system was ran on Doc Nugent's 914 Lite project. Worked great for his car.914 Lite Project Page
Lifted from the siteA "big four" displacing 2.5 liters (2499cc to be exact): 103mm bore and 75mm stroke with CB Performance's Ultra Competition fuel injection (four 31 lb. injectors in a pair of Weber-like 48mm throttle bodies)," As for meeting the sub $1K price. Simplest is MicroSquirt, and stock EFI parts. You could change your injects to hi resistance units to save a bunch of resistors hanging out. The MicroSquirt is pretty small and water tight so mount it where ever you wish. Might be able to do that build pretty cheap, I would get a 1.7, or 1.8L intake, they flow better than the 2.0L does. And more even fill of the runners. |
914_teener |
Apr 3 2014, 11:27 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
CB Compitition Fuel injection system was ran on Doc Nugent's 914 Lite project. Worked great for his car.914 Lite Project Page Lifted from the siteA "big four" displacing 2.5 liters (2499cc to be exact): 103mm bore and 75mm stroke with CB Performance's Ultra Competition fuel injection (four 31 lb. injectors in a pair of Weber-like 48mm throttle bodies)," As for meeting the sub $1K price. Simplest is MicroSquirt, and stock EFI parts. You could change your injects to hi resistance units to save a bunch of resistors hanging out. The MicroSquirt is pretty small and water tight so mount it where ever you wish. Might be able to do that build pretty cheap, I would get a 1.7, or 1.8L intake, they flow better than the 2.0L does. And more even fill of the runners. OK....but...how many people have done this? Meaning MS with the stock components. Please raise your hands for under a $1,000 |
Mark Henry |
Apr 3 2014, 05:05 PM
CB Compitition Fuel injection system was ran on Doc Nugent's 914 Lite project. Worked great for his car.914 Lite Project Page Lifted from the siteA "big four" displacing 2.5 liters (2499cc to be exact): 103mm bore and 75mm stroke with CB Performance's Ultra Competition fuel injection (four 31 lb. injectors in a pair of Weber-like 48mm throttle bodies)," As for meeting the sub $1K price. Simplest is MicroSquirt, and stock EFI parts. You could change your injects to hi resistance units to save a bunch of resistors hanging out. The MicroSquirt is pretty small and water tight so mount it where ever you wish. Might be able to do that build pretty cheap, I would get a 1.7, or 1.8L intake, they flow better than the 2.0L does. And more even fill of the runners. OK....but...how many people have done this? Meaning MS with the stock components. Please raise your hands for under a $1,000 I've done it for $1200 with SDS and stock ignition and most of the stock intake bits. Obviously talking no labour $. I did it for just over $1400 with crankfire ignition on my 1.8 with mostly d-jet parts. But this is full pop for a new SDS system, I see systems all the time on evilbay and Craigslist for 500-600 bucks. |
Lo-Fi Version | Time is now: 12th June 2024 - 07:16 AM |
