fduval |
Newbie ![]() Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada ![]() |
Hi , I am new to the 914 ownership, just bought the car from member KADUKU !
The rear end of the car is kind of very soft, I guess the rear shocks need to be replaced, what do you guys recommend for street use . The car is a 1973 with a 2 liter engine. Thanks |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,935 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far Lots of auto parts stores will lend spring compressors, that's what i did You don't need Spring Compressors! Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done! I needed them compressed to get the bolt back on the shock with the new springs. I could get it close but after a half hour of trying I drove the 2 miles to the shop and got it done. If you had sat in the Trunk, your weight would have compressed the Springs and you would have gotten the nut on |
Lo-Fi Version | Time is now: 6th July 2025 - 03:58 PM |
