| bdstone914 |
Apr 19 2014, 09:47 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I heard this can be done but have not tried it. The differences are that the 924 switch has ony one rider for the horn and has the 4 and 5th wires swapped in the loom. I do not think this matters as those two are bridged when the left turn signal is applied.
Any body tried It? Attached thumbnail(s) |
| Elliot Cannon |
Apr 19 2014, 10:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I bought a 924 switch and installed it about 9 years ago. It works great but I can't remember what I had to do. I seem to recall trimming some of the plastic wire channels off that weren't needed or didn't fit. It took a little work but it eventually fit. I realize I'm not much help here but it WILL work.
Cheers, Elliot |
| Qarl |
Apr 19 2014, 10:10 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Yes you can... I wrote this about 14 years ago.
http://www.pelicanparts.com/techarticles/9...tric_washer.htm |
| bdstone914 |
Apr 19 2014, 10:23 PM
Yes you can... I wrote this about 14 years ago. http://www.pelicanparts.com/techarticles/9...tric_washer.htm Karl, Thanks but that is for the wiper switch not the turn signal switch. Elliot, The connector seems to be the same on the one I have. But if you did it I guess it works. Bruce |
| Elliot Cannon |
Apr 20 2014, 07:43 PM
Yes you can... I wrote this about 14 years ago. http://www.pelicanparts.com/techarticles/9...tric_washer.htm Karl, Thanks but that is for the wiper switch not the turn signal switch. Elliot, The connector seems to be the same on the one I have. But if you did it I guess it works. Bruce Sorry Bruce. I think mine was a wiper switch as well. DOH!! I haven't been drinking scotch, I just can't remember much from 9 years ago. |
bdstone914 914 versus 924 turn signal switches - Can you sibstitute? Apr 19 2014, 09:47 PM
Qarl
Karl,
Thanks but that is for the wiper switch not... Apr 19 2014, 10:28 PM
Qarl Yes you can... certain years.
According to Jeff B... Apr 19 2014, 10:36 PM
Qarl And if you have a copy of Hussey's "Tech ... Apr 19 2014, 10:46 PM
Chris H. Just FYI that book says the 1975-76 switches do no... Apr 20 2014, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:07 AM |
