> I think I am the first, Putting on my Nomex suit
914-d
post Apr 20 2014, 09:23 PM
Ok, here goes.
I have been a member here since last June. Have always loved 914's since they first came out, but do you realize how much money 3500 bucks was back then...
Well, after many (and I do mean many) cars in my life, I have come close to full circle and have my first 914.
Now here is where things get different. I am doing a swap...an engine swap. I know that is kind of rare in the 914 community (TIC) but I am doing things a little (lot) different.
My friends are aware of what I am doing, and some of them don't agree. I am on another forum and have a lot of support. I have done several swaps on other platforms, and consider my self a bit of a purist and feel ther should be some congruity in the project.
I have a bit of an issue, with american v8 conversions... but to each his own.
Subie, I can see it, after all, where did they get their design/ concept from.
Wankel....ok it is a german design....but.
Audi motor trans I can get behind. (found a 914 for sale with an audi auto trans for sale...not for me).
I have always considered the 914 as much or more a VW than a Porsche. Depending on your particular bend, I guess you can go either way.
As I stated I am a bit of a purist.
I will be using the entire drivetrain from a 1999 new beatle...TDI...in the rear, and transverse.
I will be keeping it all German, All VAG. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
I haven't found anyone else with a diesel 914, maybe this will be a first
914-d
post Apr 21 2014, 10:48 AM
""You should talk to Mike Bellis. He isnt far from you and did a very similar swap though he wanted power not mpg (He is using a 1.8t)""
Is that his screen name, or how do I contact him.
One of the great things about using the tdi, is you can have the power, and the milage. This motor will run up to 200 hp and 300 tq, and return great milage.
I think you guys are over estimating how much the balance will change by going transverse. Remember, the bulk of the 901 is behind the axel. I dont know for a fact, but i am betting the tdi motor with cast iron block weighs in more that the 1.7 motor.. The only part of this setup that will be behind the axel center line will be half of the differential. all else will be forward of the axel. Also if necessary, the fuel tank will be moved forward in the tire well (fuel cell), bur radiator will most likely live in the rear.
ConeDodger
post Apr 21 2014, 11:00 AM
Apex killer!
QUOTE(914-d @ Apr 21 2014, 08:48 AM) *
Mike just commented in your thread. He's the one who says, and I agree, your plan moves your CG too far rearward. Yes, it is his screen name. While I have known him, he has had several different engines in his 914. Currently an Audi...
914-d   I think I am the first   Apr 20 2014, 09:23 PM
914-300Hemi   :wttc: It would be a interesting build. Good luck...   Apr 20 2014, 09:26 PM
Mike Bellis   I look forward to the build. I like Audi conversio...   Apr 20 2014, 09:29 PM
914-d   the Beatle tdi is transverse. I have a Passat tdi ...   Apr 20 2014, 10:00 PM
Mike Bellis   the Beatle tdi is transverse. I have a Passat tdi...   Apr 20 2014, 10:17 PM
ConeDodger   the Beatle tdi is transverse. I have a Passat td...   Apr 21 2014, 10:43 AM
Vacca Rabite   So you are taking a mid-engine car and making it a...   Apr 21 2014, 07:14 AM
KELTY360   How does a purist put a water cooled engine in an ...   Apr 21 2014, 08:14 AM
stugray   I have a passat TDI and a 914. So if you need s...   Apr 21 2014, 08:48 AM
Dave_Darling   No Nomex required--but it will be a lot easier, an...   Apr 21 2014, 10:26 AM
914-d   Yes I have the 914 and the complete Beatle tdi. I ...   Apr 21 2014, 10:28 AM
Mike Bellis   Yes I have the 914 and the complete Beatle tdi. I...   Apr 21 2014, 08:35 PM
2mAn   Im all for watercooled VW motors in these cars. Th...   Apr 21 2014, 10:37 AM
914-d   ""You should talk to Mike Bellis. He isn...   Apr 21 2014, 10:48 AM
ConeDodger   ""You should talk to Mike Bellis. He is...   Apr 21 2014, 10:52 AM
ConeDodger   ""You should talk to Mike Bellis. He is...   Apr 21 2014, 11:00 AM
914-d   I edited one of my earlier posts, should have made...   Apr 21 2014, 06:42 PM
garrettlee1   Orchideuro.com imports watercooled vw stuff from t...   Apr 22 2014, 12:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
