> New 4CYL Porsche?
Bulldog9
post Apr 28 2014, 07:07 PM
Sorry if this is a re-post, but just came across this. Interesting possibilities, wonder if it will come to the U.S.
http://www.autonews.com/article/20140321/O...ter-report-says
ClayPerrine
post Apr 29 2014, 06:33 AM
Sounds like an alternative to a Subi conversion for a 914, complete with transmission, and you can still participate at Parade.
914forme
post Apr 29 2014, 01:12 PM
QUOTE(ClayPerrine @ Apr 29 2014, 08:33 AM) *
okay if they bring them over I will (IMG:style_emoticons/default/av-943.gif) if they are a rebadged Subaru engine. Stranger things have happened.
ClayPerrine
post Apr 29 2014, 01:21 PM
QUOTE(914forme @ Apr 29 2014, 02:12 PM) *
Did you realize that the first Subaru flat 4 was a Type 1 VW engine converted to water cooling? They later converted it to overhead cams, but the crank, rods and pistons would interchange with the VW stuff. The 2.7L Six in the Subaru SVX was a water cooled 911 2.7 engine. They were so close that you could use the subi main and rod bearings in a 911 engine. The crank wouldn't interchange because Subaru redesigned the nose to work with the timing belt.
So a rebadged Subaru motor would be kind of appropriate.
wobbletop
post Apr 29 2014, 03:18 PM
QUOTE(ClayPerrine @ Apr 29 2014, 03:21 PM) *
Do you have any links to back up that history?
How do you convert an aircooled engine to water cooling? And the SVX was always 3.3L.
Steve Pratel   New 4CYL Porsche?   Apr 28 2014, 07:07 PM
r_towle   About time.   Apr 28 2014, 07:55 PM
RJMII   I like the drop top. :-) up to 395hp?   Apr 28 2014, 11:28 PM
ClayPerrine   Sounds like an alternative to a Subi conversion fo...   Apr 29 2014, 06:33 AM
914forme   Sounds like an alternative to a Subi conversion f...   Apr 29 2014, 01:12 PM
ClayPerrine   Sounds like an alternative to a Subi conversion ...   Apr 29 2014, 01:21 PM
wobbletop   Did you realize that the first Subaru flat 4 wa...   Apr 29 2014, 03:18 PM
Qarl   I'd love some more info on this new engine.   Apr 29 2014, 03:28 PM
Chris H.   Did you realize that the first Subaru flat 4 w...   Apr 30 2014, 07:16 AM
ClayPerrine   [quote name='wobbletop' post='2030992' date='Apr ...   Jul 3 2014, 01:59 PM
Jon H.   [quote name='914forme' post='2030941' date='Apr 2...   Apr 29 2014, 05:34 PM
boxsterfan   I know the Boxster is essentially the modern 914, ...   Apr 29 2014, 10:02 AM
Dave_Darling   I know the Boxster is essentially the modern 914,...   Apr 29 2014, 12:45 PM
Qarl   I know the Boxster is essentially the modern 914 ...   Apr 30 2014, 06:53 AM
Johny Blackstain   Its actually a modern 550 Spyder. That was the ...   Apr 30 2014, 07:00 AM
stugray   I will venture a guess: 2.5L Direct & port in...   Apr 29 2014, 10:52 AM
Marty Yeoman   Sounds like it will be shorter but just as wide as...   Apr 29 2014, 01:12 PM
wndsnd   Funny, I met a guy driving a Boxter on the ferry ...   Apr 29 2014, 03:58 PM
Tom   Well, the 919 engine, (it's a V4) , is a two l...   Apr 30 2014, 06:41 AM
Qarl   Maybe some more clues??? It's not a boxer-fou...   Apr 30 2014, 07:28 AM
dlkawashima   Coming in 2016 ... maybe http://www.automobilemag...   Jul 2 2014, 02:39 PM
- Lo-Fi Version Time is now: 1st August 2025 - 08:37 AM
