PMB Performance - Mike Krieger Build, Sorting out a -6 conversion and going 3.6 |
Eric_Shea |
Dec 7 2013, 11:01 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hey Gang,
We've been working on this one for a while now and I thought you'd like to follow along. It has a lot of "914" issues to sort through and can be a good piece to show how and why to fix things properly, especially with the value of these cars climbing and the money invested in a car of this quality. Mike came to us last year after finding us here for a PPI. In this case it was a "Post Purchase Inspection". The car was sold as a rust free (yes, enter your comments here) 3.2 six conversion. It turns out it was anything but. Regardless, Mike was in for the long haul and, he was determined to do things properly. He expressed interest in making the car a wide-body and fixing what needed to be fixed at the time. Off the tub went to be stripped and prepped for flares and paint work. Here you can see the "after" shot with the flares on and glass panels being fitted: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435699.1.jpg) There was a lot of metal work needed as indeed... the rust was free on this one. Before flares could go on, a new quarter panel was needed and various stiffening kits (factory and 914LTD) added to ensure minimal twist with an impending 3.6 install. The car was then painted "Signal Orange" and given back to Mike for some detail installments. Fast forward to present day. We picked the car up from Mike and began ticking off items on his wish list. Install driving lights, front turn signal buckets, hood lights, hood pins, sway bar, get turn signals working, various trim pieces etc. Here's how it it sat when we got'er in the shop: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-a-lga.xx.fbcdn.net-1110-1386435700.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435701.3.jpg) Then the "inevitable" happened. It began to act like any other DAPO 914. She began to show some of her true colors. I actually think the car was talking to us and letting us know about the problems before she burned to the ground in a heap of smoke and flames. Let's start with wiring because we basically had to re-wire the car. What started as a simple request to "get the rear light buckets working" brought us to a few swapped wires on the install post paint and then... funny smells and blown fuses. When we looked at the fuse block we saw this: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-a-lga.xx.fbcdn.net-1110-1386435702.4.jpg) Yes, the blown fuse was also a 16a!! Needless to say, this was one of the first things we did... (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435702.5.jpg) We also found some previous melted wires that could have been catastrophic: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435703.6.jpg) This caused us to start at the front and completely go over all of the wiring. Fix and replace with proper factory colored wires from a donor harness and wrap everything back up with the early cloth tape loom. The factory driving light harness was cut and crimp on ends were all that existed in the apron. We went into the harness and soldiered in new leads and used factory sheathing to bring them through the grommets in the front apron. Mike wanted these PIAA lights so we then soldiered the PIAA ends on the factory wires and inserted them back into the connectors for a clean, clip-on installation: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435704.7.jpg) Next we did the same thing while repairing the horn leads. Removed the crappy blue crimp on connectors and went full factory with the protective sheath. We also ran a second lead over for dual tone horns. (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435704.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435705.9.jpg) Here's a shot of Mike's new harness: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-lga.xx.fbcdn.net-1110-1386435786.1.jpg) |
Eric_Shea |
Apr 30 2014, 06:57 AM
So much has been done but so little to show! I guess the engine and tranny in place make for a good start. Hood lights and pin retainers on. Roughed in the ride height. Massive rubber fits!!
It looks like we'll still need to adjust the lights a bit but, they are on and wired. The lights themselves are extremely impressive. The wiring inside them was not. Very short with with inexpensive bullet plugs that would pop out at will. We went through and fixed all of that... (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-a-sjc.xx.fbcdn.net-1110-1398862622.1.jpg) The engine and tranny are in (as mentioned) and only a bit of harness work to be performed. This is a test fit which allowed us to cinch up the oil hard and soft lines and resolve the intake and other various fitment issues. You can see the purchased 14-pin engine harness connector laying on the top. Only 5 of the pins in this "purchased" harness were correct. Reverse lights were missing and the low oil indicator was going to the hand lever for the heater blower switch! (IMG:style_emoticons/default/wacko.gif) We had to go in and add the reverse wires and change (quite) a few things around. In the end... just purchase a few 14-pin ends and do it yourself. (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-h-a.akamaihd.net-1110-1398862624.2.jpg) All of the fuel lines and hoses have been run. Just a little tidying up to do there and it should be good to go. (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-sjc.xx.fbcdn.net-1110-1398862624.3.jpg) The engine will come back out one more time as we have the front tin being finalized and, we want to get back in the engine compartment to clean up and re-tape the main harness. I'd have to say, wiring on this car ate up the most hours but, I'm crazy about that stuff. Nothing worse than chasing a short in an unknown harness with crimp on connectors. With the engine and DME install, this will be the last bit of harness to clean up. Everything will be wrapped in a factory cloth tape. We installed a nice system for the hood pins (and yes, buttheads... we installed a set on my car as well) (IMG:style_emoticons/default/dry.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-c-a.akamaihd.net-1110-1398862624.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-b-a.akamaihd.net-1110-1398862625.5.jpg) We also set a preliminary ride height with the motor and trans in. Hard to believe but, it looks as though the massive rubber will fit! (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-sjc.xx.fbcdn.net-1110-1398862625.6.jpg) |
worn |
Apr 30 2014, 02:03 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The wiring inside them was not. Very short with with inexpensive bullet plugs that would pop out at will. We went through and fixed all of that... You can see the purchased 14-pin engine harness connector laying on the top. Only 5 of the pins in this "purchased" harness were correct. Reverse lights were missing and the low oil indicator was going to the hand lever for the heater blower switch! (IMG:style_emoticons/default/wacko.gif) We had to go in and add the reverse wires and change (quite) a few things around. In the end... just purchase a few 14-pin ends and do it yourself. Very impressive. I have bullet connections in the British cars. Work fine if they are the right ones and done properly. Not a favorite though. My big question is: why stay with the 14 pin plug at all. Seems like so many of the circuits don't belong together in the first place, but were convenient when the relay board was being used. I was thinking about some of the weatherproof multipin connectors you can find at Jegs etc.. Maybe one for lighting another for starting and running the engine, etc. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:10 AM |
