Test Picture, 914-6 |
DonTraver |
Aug 10 2004, 12:09 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
I posted a couple of pictures this morning, they were too large, so this is a test to see if I reduced a picture right.
Attached image(s) |
DonTraver |
Aug 10 2004, 11:28 PM
The engine shroud is painted, but first you need to clean it really good, soak it in degreaser for a few days. Then rough sand the top, not the underside, leave that side alone. I used 40 grit wet & dry, after that's done, reglass with resin. This seals out all the years of oil soaking into fiberglass that you won't get out. If you don't reglass, the oil that you don't get out will lift the paint when the engine gets hot. Then when the resin has set, wet sand without going thru with 80 grit. Prime with epoxy primer, wet sand and shoot what ever color you want. I used PPG Delstar paint. Same color Blue as the flames I painted on my bike.
Yeah, I raced with POC in 2002, even won some Kuhmo bucks with them. 2003 decided to remodel house, gave away all my furniture, stripped house. Have learned one thing about remodeling, it you're not insane when you start, you soon will be, lol. May start racing next year, have been practicing in mountains, best day to practice is Wed. Best time, San Diego to Hemet, 240 miles, 4 hours. Drew, yeah I can make your car look like that, but it isn't cheap. Example, Digital gauges, $500 material without fittings, interior, $1000 just for leather, paint job $1500+ for paints. As I've told others, I will help you and teach you how to do it. but I don't hire out. How's that sound? |
Lo-Fi Version | Time is now: 7th June 2024 - 05:52 PM |
