> Streets of Willow off rebuild, started pushing out the dents
yeahmag
post Apr 22 2014, 03:07 PM
Thanks to Bruce Stone I have some sheet metal to work with. My plan is as follows:
* Plan A:
Use a Port-a-power to push as much of the metal back in to shape and hammer and dolly from there. I have at least one line on an affordable body shop to do the finish work after I rough it in.
* Plan B:
Push some metal back and cut and weld in parts from the lot that Bruce secured for me.
* Plan C:
Push the fronts back in as close as I can get and flare the rear with QRS panels and Duz fastners.
yeahmag
post May 7 2014, 12:30 PM
Started work pushing the dents out using a port-a-power. I'll be moving to a hammer and dolly from here to do the finishing work.
yeahmag   Streets of Willow off rebuild   Apr 22 2014, 03:07 PM
yeahmag   Here's pictures of the damage again:   Apr 22 2014, 03:09 PM
yeahmag   RE: Streets of Willow off rebuild   Apr 22 2014, 03:10 PM
Dr Evil   For race only, I like the detachable fenders with ...   Apr 22 2014, 06:17 PM
yeahmag   Started work pushing the dents out using a port-a-...   May 7 2014, 12:30 PM
yeahmag   RE: Streets of Willow off rebuild   May 7 2014, 12:31 PM
396   Looking good. Good luck with the repairs   May 8 2014, 12:16 PM
Chris H.   Wow your door gaps look great compared to where th...   May 8 2014, 12:24 PM
Jmkorfha   Looking good. And familiar. I didn't have the ...   May 8 2014, 02:45 PM
yeahmag   Here is the front fender after some hammer and dol...   May 19 2014, 05:36 PM
yeahmag   RE: Streets of Willow off rebuild   May 19 2014, 05:37 PM
yeahmag   I think the rear quarter is a goner though. I...   May 19 2014, 05:38 PM
Elliot Cannon   You shoulda gone with plan C. :D Is that my old ...   May 19 2014, 10:54 PM
yeahmag   Don't tempt me Elliot! That extra $40...   May 20 2014, 04:55 PM
yeahmag   Spare panel is cleaned and ready. Starting work on...   Jun 8 2014, 04:57 PM
yeahmag   Just some loose cuts to help start fitting the new...   Jun 8 2014, 04:58 PM
r_towle   If your friend has an English wheel.....see if he ...   Jun 8 2014, 05:33 PM
yeahmag   He does, but I'm only doing one fender, so I m...   Jun 8 2014, 06:23 PM
yeahmag   Test fitting has begun.   Jun 17 2014, 10:57 AM
yeahmag   A few more pictures of us fitting the replacement ...   Jun 27 2014, 03:24 PM
yeahmag   RE: Streets of Willow off rebuild   Jun 27 2014, 03:24 PM
yeahmag   RE: Streets of Willow off rebuild   Jun 27 2014, 03:25 PM
Socalandy   Nice work!!!   Jun 27 2014, 03:34 PM
rick 918-S   Looks like its working out fine! :sawzall: :s...   Jun 28 2014, 02:57 AM
yeahmag   Trial fitting is over and we have started welding....   Aug 4 2014, 03:56 PM
yeahmag   RE: Streets of Willow off rebuild   Aug 4 2014, 03:57 PM
yeahmag   RE: Streets of Willow off rebuild   Aug 4 2014, 03:58 PM
yeahmag   Starting to work on the tail light/bumper sections...   Aug 4 2014, 04:17 PM
914_teener   It looks really good Aaron. If you are going to g...   Aug 4 2014, 05:00 PM
yeahmag   Never heard of Evidure... I am going to grind th...   Aug 4 2014, 05:05 PM
914_teener   Sorry....I'm getting old. I think it is spell...   Aug 4 2014, 05:14 PM
yeahmag   Ah... I've had really good luck with the stuff...   Aug 4 2014, 05:19 PM
yeahmag   Turns out I had a cracked/torn stub pipe too. Used...   Oct 27 2014, 07:38 PM
yeahmag   And here is what I found.   Oct 27 2014, 07:39 PM
yeahmag   I drilled the ends of the crack/tear to relieve an...   Oct 27 2014, 07:42 PM
Philip W.   any updated pictures of the welding/ paint progres...   Oct 28 2014, 08:42 AM
yeahmag   Nothing new there. I plan to weld in the longitudi...   Oct 28 2014, 03:25 PM
yeahmag   Finally got some time yesterday to make some headw...   Feb 2 2015, 03:38 PM
yeahmag   After sanding I laid down a guide coat. I've g...   Feb 2 2015, 03:39 PM
yeahmag   Closer still... Going to use some 2 part glazing t...   Jun 15 2015, 12:41 PM
- Lo-Fi Version Time is now: 1st August 2025 - 02:32 PM
