> Gas Cap Through Front Hood
Larmo63
post May 7 2014, 12:01 PM
I know the race 914 guys have probably done this, but I want to space my gas filler higher, cut a hole in the front hood and fill fuel through the opening. I have a few ideas on doing a "GT" type cap and how to do a spacer and rubber skirt, who has done this?
Pictures? Threads?
Larmo63
post May 7 2014, 03:41 PM
I love the cap that Eric has on the yellow car....Do those fit our 914 tanks?
My idea is to machine an aluminum spacer to make the filler sit up a bit higher, use longer bolts in the eight holes, gaskets top
and bottom, run rubber foam around the stock skirt and it would seal to the hood if done with the right seal. If no GT cap is available, I
was thinking a fin could also be made/cnc'd to adhere or rivet/screw onto the stock cap to "sexy" it up....? Paint or powder coat the cap...?
Thinking out loud.
Larmo63   Gas Cap Through Front Hood   May 7 2014, 12:01 PM
r_towle   Check out Eric Shea and his restoration. I think h...   May 7 2014, 12:14 PM
BKLA   Mittlemotor in germany has a GT filler "Kit...   May 7 2014, 12:20 PM
bdstone914   I have a white hood that is already modified with ...   May 7 2014, 02:30 PM
Qarl   Since this topic has been brought up... I am in t...   May 7 2014, 03:14 PM
Larmo63   I measured this on my car to the center of the cap...   May 7 2014, 03:37 PM
ThePaintedMan   I did mine by taping a sharpie centered in the fue...   May 7 2014, 03:39 PM
Larmo63   I love the cap that Eric has on the yellow car.......   May 7 2014, 03:41 PM
iamchappy   Not through the hood filler cap but hope it helps ...   May 7 2014, 03:59 PM
TJB/914   Not through the hood filler cap but hope it helps...   May 7 2014, 05:53 PM
TJB/914   Not through the hood filler cap but hope it help...   May 7 2014, 06:08 PM
9146R   I know the race 914 guys have probably done this...   May 7 2014, 04:58 PM
brant   and   May 7 2014, 06:10 PM
Harpo   If eric is using the 110mm blau cap then you will ...   May 7 2014, 06:26 PM
Larmo63   There are many types of racing style fuel fillers ...   May 7 2014, 06:35 PM
zambezi   Heres a couple threads with info http://www.914wo...   May 7 2014, 06:54 PM
iamchappy   Mounted that way because of the slope on the hood....   May 7 2014, 07:39 PM
carr914   I love the cap that Eric has on the yellow car......   May 7 2014, 08:40 PM
bdstone914   I have a white hood that is already modified with ...   May 7 2014, 09:35 PM
Larmo63   I'll take a cap and filler neck......?   May 7 2014, 09:40 PM
sixnotfour   a long time ago,,, stock cap with machined cap pre...   May 7 2014, 10:17 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:46 PM
