> What tool do you use to tighten front strut insert nut? Oops move me to Garage., I have heard that when they back off a bit it can cause a bang
wndsnd
post May 8 2014, 07:45 PM
You wanted a horse, but got a goat. Nobody wants a goat....
I am trying to hunt down a front end noise, a metallic sounding bang over bumps front right.
My suspicions are
A). Sway bar drop links
B) sway bar hitting tank
C) strut nut.
Normal tests seem fine, checking ball joint and tie rod ends.
John
wndsnd
post May 11 2014, 04:12 PM
Yes I have the Bilsteins.
Thanks for the narrative Rich.
wndsnd   What tool do you use to tighten front strut insert nut? Oops move me to Garage.   May 8 2014, 07:45 PM
mskala   I have some kind of old plumbing wrench that's...   May 8 2014, 08:53 PM
tommy914   The tool I use.   May 8 2014, 09:07 PM
messix   cheap ass harbor freight pipe wrench   May 8 2014, 09:30 PM
r_towle   Pipe wrench or the proper strut wrench. Motorcycl...   May 9 2014, 05:22 AM
Krieger   Check the three allen head bolts that hold the str...   May 9 2014, 08:07 AM
Elliot Cannon   It could be your shock is shot allowing it to bott...   May 9 2014, 07:09 PM
r_towle   I am shocked you had a shot shock...   May 10 2014, 10:54 AM
r_towle   Do you have a front anti sway bar? If so, what typ...   May 10 2014, 10:57 AM
wndsnd   Do you have a front anti sway bar? If so, what ty...   May 11 2014, 12:03 PM
Racer Chris   I inspected the front end when John stopped here f...   May 10 2014, 11:58 AM
ClayPerrine   From recent experience: Both our 914s had an issu...   May 11 2014, 11:03 AM
wndsnd   Thanks everyone, those housing nuts seem to be the...   May 11 2014, 12:02 PM
wndsnd   Can I do these by dropping from the top without ta...   May 11 2014, 12:07 PM
Racer Chris   Can I do these by dropping from the top without t...   May 11 2014, 01:48 PM
r_towle   Jack up one side of the car, or both..no differenc...   May 11 2014, 03:52 PM
struckn   Jack up one side of the car, or both..no differen...   May 11 2014, 06:56 PM
wndsnd   Yes I have the Bilsteins. Thanks for the narrativ...   May 11 2014, 04:12 PM
r_towle   Then be careful....   May 11 2014, 04:14 PM
r_towle   It's not terrible, just a lot of pressure to h...   May 11 2014, 04:15 PM
worn   I am trying to hunt down a front end noise, a met...   May 11 2014, 09:47 PM
wndsnd   Took the front suspension down today. Removed str...   May 17 2014, 12:26 PM
- Lo-Fi Version Time is now: 14th August 2026 - 04:20 AM
