| wndsnd |
May 8 2014, 07:45 PM
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I am trying to hunt down a front end noise, a metallic sounding bang over bumps front right.
My suspicions are A). Sway bar drop links B) sway bar hitting tank C) strut nut. Normal tests seem fine, checking ball joint and tie rod ends. John |
| r_towle |
May 11 2014, 04:15 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
It's not terrible, just a lot of pressure to hang on to if you are not comfy and ready for it...
wndsnd What tool do you use to tighten front strut insert nut? Oops move me to Garage. May 8 2014, 07:45 PM
mskala I have some kind of old plumbing wrench that's... May 8 2014, 08:53 PM
tommy914 The tool I use.
May 8 2014, 09:07 PM
messix cheap ass harbor freight pipe wrench May 8 2014, 09:30 PM
r_towle Pipe wrench or the proper strut wrench.
Motorcycl... May 9 2014, 05:22 AM
Krieger Check the three allen head bolts that hold the str... May 9 2014, 08:07 AM
Elliot Cannon It could be your shock is shot allowing it to bott... May 9 2014, 07:09 PM
r_towle I am shocked you had a shot shock... May 10 2014, 10:54 AM
r_towle Do you have a front anti sway bar?
If so, what typ... May 10 2014, 10:57 AM
wndsnd
If so, what ty... May 11 2014, 12:03 PM
Racer Chris I inspected the front end when John stopped here f... May 10 2014, 11:58 AM
ClayPerrine From recent experience:
Both our 914s had an issu... May 11 2014, 11:03 AM
wndsnd Thanks everyone, those housing nuts seem to be the... May 11 2014, 12:02 PM
wndsnd Can I do these by dropping from the top without ta... May 11 2014, 12:07 PM
Racer Chris
Can I do these by dropping from the top without t... May 11 2014, 01:48 PM
r_towle Jack up one side of the car, or both..no differenc... May 11 2014, 03:52 PM
struckn
Jack up one side of the car, or both..no differen... May 11 2014, 06:56 PM
wndsnd Yes I have the Bilsteins.
Thanks for the narrativ... May 11 2014, 04:12 PM
r_towle Then be careful.... May 11 2014, 04:14 PM
worn
I am trying to hunt down a front end noise, a met... May 11 2014, 09:47 PM
wndsnd Took the front suspension down today. Removed str... May 17 2014, 12:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 04:19 AM |
