eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
This is an early steering column--'70 -- with an oddball ignition switch. It has a VW logo and the key positions are marked LIG. PARTIDA TRAVA DESL. The key is not a Porsche key. I wonder if it might be for a Mexican or Brazilian Bug...? (Stupid DAPO!!!)
Anyway, I have power to the column but it doesn't get past the switch. And I want to replace the whole cylinder anyway to use a Porsche key. When I first got the car I pulled the engine right away. I didn't test the lights and switches at the time except for starting and running it a bit. It was a -6 conversion that ran like KRAP. I can only get two positions with the key but the wheel locks and unlocks. And I have no idea how to get that key cylinder and switch out. Can anybody help? (Haynes sure isn't any help on this one.) ![]() ![]() ![]() |
housepumpinpc |
Give me time... I'll fix it eventually. ![]() Group: Members Posts: 31 Joined: 9-May 14 From: Chicago,Illinois Member No.: 17,323 Region Association: Upper MidWest ![]() |
This is an early steering column--'70 -- with an oddball ignition switch. It has a VW logo and the key positions are marked LIG. PARTIDA TRAVA DESL. The key is not a Porsche key. I wonder if it might be for a Mexican or Brazilian Bug...? (Stupid DAPO!!!) Anyway, I have power to the column but it doesn't get past the switch. And I want to replace the whole cylinder anyway to use a Porsche key. When I first got the car I pulled the engine right away. I didn't test the lights and switches at the time except for starting and running it a bit. It was a -6 conversion that ran like KRAP. I can only get two positions with the key but the wheel locks and unlocks. And I have no idea how to get that key cylinder and switch out. Can anybody help? (Haynes sure isn't any help on this one.) ![]() ![]() ![]() Looking at it have you tried turning the ignition with the key installed and pull on the key? Some other cars i dealt with have a pin release that you depress with the key in the just before you crank position. Now if you don't have a key...drill baby drill. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 03:33 PM |
