| ericoneal |
May 11 2014, 07:34 PM
Member ![]() ![]() Group: Members Posts: 327 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I'm planning to really start tackling some of my oil leaks tomorrow. I was under there tonight and the pushrod tubes are leaking (used the crappy seals when I changed them over the winter), along with the taco plate (I have one, easy fix).
What is bothering me is that there are drop of oil on the head fins and oil tins under them on both sides of the car. Its not in a place where oil would blowback from the pushrod tube seals, and my head vent hoses up top are not leaking either. Can you guys tell me where the source of oil for a leak like this could be? Cant find anything in the search. Thanks |
| Bob L. |
May 11 2014, 08:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I had some oil leaking from the valve cover on the passenger side that got blown up with the cooling air. it also looked like is was coming from a push rod tube but it wasn't.
ericoneal Oil drop on engine tin May 11 2014, 07:34 PM
ericoneal Maybe your're right. If was something more se... May 11 2014, 08:18 PM
boxsterfan I recently replaced my oil pressure sending unit u... May 11 2014, 08:34 PM
walterolin Hi Eric,
If you want, I could come over later thi... May 11 2014, 08:45 PM
ericoneal Hey Walter,
That would be great, would like to see... May 12 2014, 07:46 AM
stugray
Dont forget to put that tin back in before the p... May 12 2014, 08:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 10:10 PM |
