> Questions...having alternator belt and starter issues, Best alternator belt and IMI starter issues
crash914
post May 12 2014, 06:18 PM
its a mystery to me
Hi all...
Anyone else have any problem keeping the alternator belt on a hi po 4 cylinder?
Whenever I get up to around 6500 to 7000 rpm, the belt flies off....I keep putting it back on, but I can't keep having this problem...What is everyone using for their high reving type 4's.
2nd question. Anyone else having problems with the high torque IMI starters? I have to use 2 batteries to crank this thing over...I did go out and get the newest largest battery I could find (it is in the front trunk). I think that the solenoid might be sticking...this has been off the road for 8 years if that matters...sometimes it seems that the solenoid doesn't release...then a clunk when I turn off the key...
thoughts? other than using bus pistons....motor is 103 by 80 with around 10:1 compression....
edwin
post May 12 2014, 07:18 PM
Region Association: Australia and New Zealand
Did you check the drop when cranking or static? Need to test at the starter while cranking.
- Lo-Fi Version Time is now: 3rd March 2026 - 06:30 AM
