| crash914 |
May 12 2014, 06:18 PM
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Hi all...
Anyone else have any problem keeping the alternator belt on a hi po 4 cylinder? Whenever I get up to around 6500 to 7000 rpm, the belt flies off....I keep putting it back on, but I can't keep having this problem...What is everyone using for their high reving type 4's. 2nd question. Anyone else having problems with the high torque IMI starters? I have to use 2 batteries to crank this thing over...I did go out and get the newest largest battery I could find (it is in the front trunk). I think that the solenoid might be sticking...this has been off the road for 8 years if that matters...sometimes it seems that the solenoid doesn't release...then a clunk when I turn off the key... thoughts? other than using bus pistons....motor is 103 by 80 with around 10:1 compression.... |
| Mike Bellis |
May 12 2014, 08:30 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Many times if the belt is too tight, it will fly off at high rpm. Try to loosen it.
crash914 Questions...having alternator belt and starter issues May 12 2014, 06:18 PM
edwin There is adjustment for the alternator where it pi... May 12 2014, 06:54 PM
crash914 I will have to check the alternator alignment...
... May 12 2014, 07:00 PM
edwin Did you check the drop when cranking or static? Ne... May 12 2014, 07:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:29 AM |
