Speedo angle drive, do they go bad? |
SirAndy |
May 12 2014, 09:51 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
After replacing my broken speedo cable (torn in half) my speedo still wasn't working.
So i disconnected it at the angle drive and used a drill to drive the cable and the speedo worked just fine. I then tried to turn the angle drive spade by hand and i was able to turn it while it was making a crunchy sounds. I don't think i'm supposed to be able to turn this by hand. Anyone know for sure? (IMG:style_emoticons/default/idea.gif) PS: Can i replace this with the oil in the transmission? What if i get the car at an steep angle, would it still leak? |
Jeffs9146 |
May 12 2014, 10:11 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have had one go bad...many years ago!
As long as you put the new one in quick you should be fine! Yes some fluid will come out if you are parked at an angle and let it sit that way for a day, if you do it quickly it is not a problem! |
Bob L. |
May 12 2014, 10:25 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I have had one go bad...many years ago! As long as you put the new one in quick you should be fine! Yes some fluid will come out if you are parked at an angle and let it sit that way for a day, if you do it quickly it is not a problem! The inner drive will leak if removed or if the seal goes bad. McMark has modified them to seal better. You can remove the angle drive without a leak. At least mine didn't. |
Lo-Fi Version | Time is now: 16th June 2024 - 11:54 AM |
