jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I am sorting out my recently built 2056 specs below:
2.0 Heads were done by Len Hoffman CR 8.56:1 Full Raby valve train kit Stock L-jet throttle body, air cleaner, and intake runners stock 2.0 heat exchangers pertronix ignition It has a miss under hard acceleration. All the vacuum lines and oil cap gaskets are new and I can't seem to find a leak any where. So I decided to recheck the timing. Pulled vac lines off the vacuum diaphragm and plugged, set idle to 800 rpm timing was a little more advanced than it should be but not dramatically, but I did reset to factory setting. Drove it and it is even worse than before. Would the new engine combo warrant a different timing? Fuel filter is new but my next step is to check fuel pressures and injectors. Anything else I should be looking for? |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Can I assume that this L-Jet system was working fine before you did all the engine work?
A couple of things... If it had a bad vacuum leak it would not idle at 800rpm, so that leads me elsewhere. I'd keep looking into ignition as L-jet is pretty solid once you verify the vacuum leaks are gone. Do you have anything to swap out the pertronix to test? And I agree about the wideband 02 given the amount of money you spent on that motor, it is cheap insurance and a great tuning aid. Just avoid going lean at Full Throttle. Good luck and post the progress. |
Lo-Fi Version | Time is now: 26th August 2025 - 09:32 PM |
