| bdstone914 |
May 13 2014, 10:09 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,289 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am installing a carbed engine and was wondering if I can run the low pressure carb pump off of the same wires that the FI pump used. If there is no ECU then there would be no cut off like with D JET right ?
| boogie_man |
May 14 2014, 12:59 PM
Member ![]() ![]() Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
I am installing a carbed engine and was wondering if I can run the low pressure carb pump off of the same wires that the FI pump used. If there is no ECU then there would be no cut off like with D JET right ? When you think you're going to install that engine? Would like to be there to help and take notes for my future install.... (IMG:style_emoticons/default/beerchug.gif) Scott |
bdstone914 Fuel pump wiring for carbs May 13 2014, 10:09 PM
Gearhead1432 Check this link to the classic theads.
http://www... May 13 2014, 10:13 PM
bdstone914
http://ww... May 13 2014, 10:23 PM
SirAndy Check this link to the classic theads.
[url=http:... May 13 2014, 11:32 PM
rhodyguy yes you can bruce. you'll need to alter the st... May 14 2014, 12:00 PM
eyesright I can put this here or in the "What did you d... May 17 2014, 09:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 08:33 AM |
