i have 34 webers ,question about going larger |
rosenfe |
May 14 2014, 02:04 PM
Senior Member Group: Members Posts: 557 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73 2.0.i have 2 -34 webers with original cam,would like more power without rebuilding or changing cam.still have complete original fi,but it was not running when i got it with the fi,so we put on webers.would i do better going back to the fi,or would larger webers work?
Mblizzard |
May 14 2014, 02:24 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I just went through the change back to FI on my 2056. My opinion is that without changing the cam, you will always be leaving HP on the table regardless of the carb size. I got a pretty good punch from my 44s. But I have found that even though I have not completely dialed in the FI for my additional displacement, that the FI performs better than the carbs. Yes there are moments when the carbs have the upper hand even with the stock cam, but overall the FI is a better all-around performer if you keep the stock cam. I have the 44s sitting in the garage which will need to find a new home soon so I would like to say buy these and they will solve your problems. But my experience says the FI is the best bet with the stock cam.
Others may have more experience or actual data that says something different but so far I like the FI over carbs with the stock cam. Change the cam and it may be a different outcome. |
rosenfe |
May 14 2014, 02:41 PM
I just went through the change back to FI on my 2056. My opinion is that without changing the cam, you will always be leaving HP on the table regardless of the carb size. I got a pretty good punch from my 44s. But I have found that even though I have not completely dialed in the FI for my additional displacement, that the FI performs better than the carbs. Yes there are moments when the carbs have the upper hand even with the stock cam, but overall the FI is a better all-around performer if you keep the stock cam. I have the 44s sitting in the garage which will need to find a new home soon so I would like to say buy these and they will solve your problems. But my experience says the FI is the best bet with the stock cam. Others may have more experience or actual data that says something different but so far I like the FI over carbs with the stock cam. Change the cam and it may be a different outcome. what do you like better with the fi. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:01 AM |
