> 2056 still working out the bugs
jmargush
post May 13 2014, 03:04 PM
I am sorting out my recently built 2056 specs below:
2.0 Heads were done by Len Hoffman
CR 8.56:1
Full Raby valve train kit
Stock L-jet throttle body, air cleaner, and intake runners
stock 2.0 heat exchangers
pertronix ignition
It has a miss under hard acceleration.
All the vacuum lines and oil cap gaskets are new and I can't seem to find a leak any where.
So I decided to recheck the timing.
Pulled vac lines off the vacuum diaphragm and plugged, set idle to 800 rpm
timing was a little more advanced than it should be but not dramatically, but I did reset to factory setting.
Drove it and it is even worse than before.
Would the new engine combo warrant a different timing?
Fuel filter is new but my next step is to check fuel pressures and injectors.
Anything else I should be looking for?
jmargush
post May 14 2014, 06:52 PM
Stock heat exchangers with a Thunderbird exhaust which is similar to Bursch as far as how the plumbing runs.
Any pictures of your O2 set ups?
I made a little progress this evening
Vacuum diaphragm on dizzy was bad on the retard side thus the not coming down to idle.
Didn't get a chance to run it on the road as it was raining but I did shave the grommet for the wires running form the pertronix as they were mighty close to the plate that rotates for advance, just incase that was making the plate hang up on advance.
Hopefully I will get a chance to try it tomorrow.
Mblizzard
post May 14 2014, 07:04 PM
QUOTE(jmargush @ May 14 2014, 04:52 PM) *
Have not welded in the bung yet. Have just done the mock up. Will be tomorrow before I can get to it but I will post some pictures. The AEM AF gauge seems pretty well made. Looks like the spent the most on the O2 sensor but the wires don't look like they were done cheap and the connectors seem to be of good quality. The actual gauge is a little cheap feeling though.
jmargush   2056 still working out the bugs   May 13 2014, 03:04 PM
Mblizzard   I only suggest this because I have done it :headba...   May 13 2014, 03:20 PM
McMark   You should have a Wideband O2 sensor in there befo...   May 13 2014, 03:29 PM
Mblizzard   You should have a Wideband O2 sensor in there bef...   May 13 2014, 04:52 PM
jmargush   You should have a Wideband O2 sensor in there be...   May 14 2014, 02:53 PM
Mblizzard   [quote name='Mblizzard' post='2037083' date='May ...   May 14 2014, 03:24 PM
914_teener   He has L-jet not D-jet.   May 13 2014, 03:59 PM
Cupomeat   Can I assume that this L-Jet system was working fi...   May 13 2014, 04:04 PM
jmargush   For the wide band O2 do you weld that into the hea...   May 13 2014, 04:24 PM
Dave_Darling   once warmed up and you come to a stop the idle won...   May 13 2014, 06:03 PM
Porschef   How does it perform on a cold start? :popcorn:   May 13 2014, 05:00 PM
Mblizzard   Also check your injector seals. I had a pretty go...   May 13 2014, 05:02 PM
jmargush   Cold start performance is pretty much the same I j...   May 13 2014, 06:45 PM
Java2570   The AEM air fuel gauge I bought included the O2 se...   May 14 2014, 03:28 PM
Mblizzard   I have a Bursch exhaust. There is a good location ...   May 14 2014, 05:29 PM
Java2570   I hear ya on the back crap, I didn't start ha...   May 14 2014, 05:42 PM
jmargush   Stock heat exchangers with a Thunderbird exhaust w...   May 14 2014, 06:52 PM
Mblizzard   Stock heat exchangers with a Thunderbird exhaust ...   May 14 2014, 07:04 PM
jmargush   Well the new diaphragm on the distributor didn...   May 15 2014, 01:57 PM
Java2570   Did you ever get a check on what your fuel pressur...   May 15 2014, 02:36 PM
jmargush   I should get the pressure checked tonight so maybe...   May 15 2014, 03:07 PM
jmargush   Fuel pressure was 35psi at idle and dropped to 30p...   May 15 2014, 07:36 PM
Mblizzard   Ok here are the pics of my sensor location on a Bu...   May 16 2014, 02:33 PM
jmargush   Thanks Does the kit give pretty good instructions ...   May 16 2014, 02:55 PM
Mblizzard   Thanks Does the kit give pretty good instructions...   May 16 2014, 03:39 PM
markyb   I am sorting out my recently built 2056 specs be...   May 16 2014, 05:43 PM
jmargush   It's a 74 but I put the L-jet on because I kne...   May 16 2014, 08:41 PM
Bleyseng   If everything thing is setup correctly and no vacu...   May 17 2014, 04:56 AM
- Lo-Fi Version Time is now: 26th August 2025 - 09:37 PM
