| Bob L. |
May 15 2014, 06:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I kept having to re-torque the exhaust due to leaks, then one of the exhaust stud threads stripped out on cyl #1. I drilled it out and tried to tap it for 8mm Helicoil. The tap wouldn't grab well and now its looking like it would need to be re-drilled and tapped for a 10mm Helicoil and a step stud. (IMG:style_emoticons/default/headbang.gif)
This happens to be the same bank where I have low compression in cylinder #2. It was 110 compared to 135 on all others (cold with other plugs in) I didn't know at the time you were supposed to do it with warm engine and plugs out. at the time. Well, you learn! At least I did. So I'm thinking, I probably need some valve work on #2 and the Stud repair. So, should I look for a good used head? Should I have this one repaired? What should that cost, ballpark? Should I get a new head? I have looked around and the ones are pretty $$$ for me as are some used. The least expensive one i have seen is... http://vwparts.aircooled.net/CB-Performanc...b-044-heads.htm Aside from least expensive, are they cheap? Any good? Wrong for the type 4. And could I get only one or is that just dumb? I may be stationary for a while (IMG:style_emoticons/default/sad.gif) Thanks, Bob |
| Bob L. |
May 15 2014, 07:08 PM
It's a 2.0 out of a '76.
| bdstone914 |
May 15 2014, 07:47 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It's a 2.0 out of a '76. Fix it with a helicoli and or step stud as needed. The compression is not that bad that you need to do a valve job. If you have to pull the one head to fix it you should pull the other and have them both refreshed. It is a good idea to replace the sodium exhaust valves which get brittle and can break. Don't just do one head. You will have higher compression on that head than the other. |
Bob L. I need your thoughts on head work. May 15 2014, 06:37 PM
wndsnd That is not a Type 4 head.
What engine do you hav... May 15 2014, 06:49 PM
stugray With a 2.0L I would look to getting it inspected ... May 15 2014, 07:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:15 PM |
