jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I am sorting out my recently built 2056 specs below:
2.0 Heads were done by Len Hoffman CR 8.56:1 Full Raby valve train kit Stock L-jet throttle body, air cleaner, and intake runners stock 2.0 heat exchangers pertronix ignition It has a miss under hard acceleration. All the vacuum lines and oil cap gaskets are new and I can't seem to find a leak any where. So I decided to recheck the timing. Pulled vac lines off the vacuum diaphragm and plugged, set idle to 800 rpm timing was a little more advanced than it should be but not dramatically, but I did reset to factory setting. Drove it and it is even worse than before. Would the new engine combo warrant a different timing? Fuel filter is new but my next step is to check fuel pressures and injectors. Anything else I should be looking for? |
jmargush |
It's a 74 but I put the L-jet on because I knew it was working with the 1.8 and i didn't know the state of the D-jet that came with the engine.
Wondering if I should do a new L-jet harness if I can establish there are bad wires in this harness or try the D-jet system on the engine. |
Lo-Fi Version | Time is now: 26th August 2025 - 09:34 PM |
