ggress |
Newbie ![]() Group: Members Posts: 6 Joined: 11-May 14 From: Oregon Member No.: 17,334 Region Association: None ![]() |
Just getting a '74 2.0 running that I purchased few years back. Replaced all fuel lines, vacuum lines, and FI Harness. It runs better than I expected but not good enough.
It idles too fast (1300 / 1400 RPM) considering throttle valve bypass screw is all the way in. Also, it runs lean (using WB A/F meter). I have set the mixture adjustment on the ECU full CW to get mixture around 13.7:1. I think I have covered all the common vacuum leak issues described in other threads. Any suggestions appreciated. I have two specific questions below. 1) Is my ECU P/N correct? The base P/N is correct but not sure what the 090 suffix means. 2) With the throttle valve bypass screw turned in full CW there is still vacuum getting past the screw. Does anybody know if that is normal ? I can put my finger over the port and feel vacuum. Maybe by design it is not meant to provide positive shut off but I don't have enough experience to say one way or the other. Thx ![]() ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,878 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
You need to make sure everything is set properly such as dwell, timing, valve adjustment, vacuum hose connected to the right location, etc.
The knob on the ECU only adjusts the idle mixture. The throttle position switch sends the signal to the ECU that you actually are at idle. You need to verify that it is properly adjusted. Everything you want to know on the D-Jet FI (at least a very good portion of it) is on this website: http://members.rennlist.com/pbanders/index.html I'm sure others will chime in. Good luck and keep us posted (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 06:25 AM |
