| stinkindiesel |
May 19 2014, 01:51 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Pulled out all the old hoses this weekend, and I don't think there was a single one that wouldn't have leaked like crazy. It's a wonder the thing ran at all.
Maybe I'm suffering from a bout of surf fu flu, but I'm having a lot of trouble nailing down the proper sizes of each of the vacuum lines. I see some drawings referring to 4mm, 5mm, 8mm, and 13mm, while it looks to me like the PET calls out 3.5mm, 4mm and 12mm ID hose. Anyone who's replaced these recently remember what sizes you bought and how much of each? Unfortunately, my car doesn't look original enough to be able to just measure what was there before. There was definitively some creative routing involved, including some home-made splices between two different sizes. Also, there are 3 or 4 90 degree elbows that are quickly returning to their natural gooey dinosaur state that I can't seem to find at any of my usual parts suppliers. Source? Gary |
| stinkindiesel |
May 20 2014, 02:27 PM
Thanks, guys. I'll take a look at your suggestions.
Another question: I see most of the vacuum diagrams only showing a single connection to the distributor, but my car had both the advance and retard sides hooked up. One side was going to a home-made connection between the aux air switch and the throttle body (I think). Does this sound reasonable? There are just too many variations in vacuum systems... Gary |
| Cap'n Krusty |
May 20 2014, 02:35 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Thanks, guys. I'll take a look at your suggestions. Another question: I see most of the vacuum diagrams only showing a single connection to the distributor, but my car had both the advance and retard sides hooked up. One side was going to a home-made connection between the aux air switch and the throttle body (I think). Does this sound reasonable? There are just too many variations in vacuum systems... Gary Your car uses one vacuum line from the back (or top) of the throttle body to the advance side of the distributor vacuum can, and one slightly larger like from the side of the throttle body to the backside (retard) side of the can. The larger port is between the TB and the #2 intake runner, and it's a little tough to get to. The vacuum line tee between the AAR and the plenum goes to the decel valve. The Cap'n |
stinkindiesel 1973 1.7L vacuum hoses May 19 2014, 01:51 PM
Jeff Bowlsby Measure the nipples, the tubing is 1mm smaller, 0.... May 19 2014, 01:59 PM
Cap'n Krusty
Pulled out all the old hoses this weekend, and I ... May 19 2014, 02:10 PM
JawjaPorsche Auto Atlanta
Vacuum hose kit:
http://www.autoatl... May 19 2014, 03:59 PM
stinkindiesel
Your car uses one vacuum line from the back (or ... May 21 2014, 12:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:27 AM |
