| Elliot Cannon |
May 23 2014, 09:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
My gear box shifted "like butta" but I decided to install this anyway. It seems to be a better design, so what the hey. I'll be adjusting the shifter tomorrow.
| dirk9141973 |
May 24 2014, 05:10 AM
Unregistered |
Please report on how this kit improves shifting (IMG:style_emoticons/default/sunglasses.gif)
| ww914 |
May 24 2014, 07:17 AM
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
When I first got my car a few years ago, I replaced all the plastic bushings. It worked fine at first but then got sloppy and I had a hard time adjusting the shifter and getting it into first gear. I recently installed the Tangerine upgrade kit with the firewall bushing. It made a tremendous difference and has worked well since. At first after I installed it I was feeling some resistance in shifting to 3rd. I took it apart and found that the shift rod from the firewall to the gear shift where it slides in the firewall bushing needed to be cleaned up. After I cleaned it with emory cloth and re-greased it. It worked fine and has ever since. Never was able to get the boot on. I might try some of the listed procedures from here. ![]() |
Elliot Cannon Shift rod May 23 2014, 09:42 PM
Elliot Cannon Is it possible for someone of a certain age and ar... May 23 2014, 09:45 PM
reharvey
Is it possible for someone of a certain age and a... May 24 2014, 05:56 AM
Bruce Hinds
My gear box shifted "like butta" but I ... May 23 2014, 10:41 PM
Elliot Cannon You can find them here. http://www.tangerinerac... May 23 2014, 10:43 PM
pcar916 I always get it started at the top after smearing ... May 24 2014, 06:05 AM
Java2570 I have that Tangerine shift rod setup as well and ... May 24 2014, 06:08 AM
cary I use a window glazers tool. Looks like a tough de... May 24 2014, 07:12 AM
ThePaintedMan To get the rubber boot back on I always folded it ... May 24 2014, 07:21 AM
r_towle Hook it on top first.
Then use need nose pliers to... May 24 2014, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 02:41 PM |
