how tight, wheel bearing nut |
jacksun |
May 26 2014, 11:11 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
how tight for the nut (A) before tightening (B)
seems to be a difference in the "free spin" of the rotor if I get it too tight? tks r |
Elliot Cannon |
May 26 2014, 11:30 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I always tighten more than necessary to seat the bearings, rotate the wheel a bit, then loosen just enough to slide the washer. You can check the bearing adjustment every so often when the car is on the ground by grabbing the top of the tire and pulling back and forth. If you hear a "clicking" noise, it's too loose. I had a friend years ago who over tightened the front right wheel bearing on his VW bug. The spindle got so hot the wheel came off on the freeway and took the next off-ramp. (IMG:style_emoticons/default/av-943.gif) Luckily, there where no injuries. Just embarrassment. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 11:26 AM |
