Clutch not working? |
WifesCar |
May 27 2014, 10:03 AM
Newbie Group: Members Posts: 2 Joined: 27-May 14 From: Fernie, BC Member No.: 17,413 Region Association: Canada |
I was just taking our 1975 1.8L out of Winter storage and couldn't get it into any gears! It worked fine last fall. With the vehicle off, it runs through the gears. When it's running, I can't shift without it grinding. It reacts like there is no clutch at all.
The cable on the transmission side appears fine, although I was surprised by how little it moves when somebody engages the clutch. Is it possible for the cable to stretch over the winter? Or the threaded bolt on the end to back off! Doesn't make sense?? |
Valy |
May 27 2014, 10:15 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I was just taking our 1975 1.8L out of Winter storage and couldn't get it into any gears! It worked fine last fall. With the vehicle off, it runs through the gears. When it's running, I can't shift without it grinding. It reacts like there is no clutch at all. The cable on the transmission side appears fine, although I was surprised by how little it moves when somebody engages the clutch. Is it possible for the cable to stretch over the winter? Or the threaded bolt on the end to back off! Doesn't make sense?? Check the cable tube in the tunnel. Looks like it snapped. I see some welding in your future. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:24 PM |
