door glass separated from vertical channel |
era vulgaris |
May 27 2014, 03:36 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My driver's side door glass separated from the vertical channel it slides up and down in. I think the new scraper seals I installed where causing too much friction.
Has this happened to anyone else? What's the best adhesive to use to re-glue it? Thanks! |
era vulgaris |
May 27 2014, 08:50 PM
The pre-73 door system is different. Unless I'm mistaken, he's talking about the metal channel that has rollers on it and is on the leading edge of the window. This metal channel is only as wide as the glass, there would be no room for a thick adhesive. Yup, you're correct. It's the channel on the front edge of the window. Is there any way to re-attach it? I was thinking about this stuff maybe? http://www.loctiteproducts.com/p/sg_glass/...-Glass-Glue.htm |
Lo-Fi Version | Time is now: 1st June 2024 - 03:55 PM |
