valve adjustment screws, anyone tried these ones from pelican?? |
jeremiah98125 |
Apr 9 2010, 12:49 PM
jr Group: Members Posts: 37 Joined: 11-November 09 From: seattle, wa Member No.: 11,031 Region Association: Pacific Northwest |
I didn't check out my valve adjustment screws last time I adjusted the valves and they seem a bit noisy to me.. (BTW how noisy should they be??) so I was going to pickup a new set of the adjuster screws to have on hand in case mine look worn the next time I go down there. Wondering if anyone has an opinion on these ones for my 1.7 from Pelican:
http://www.pelicanparts.com/cgi-bin/smart/...0-73)%2C%20Each $4/ea seems like a good price, just wondering if anyone's tried them out before? they don't mention what brand they are.. |
Java2570 |
May 27 2014, 06:52 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
The 911 swivel foot adjusters are definitely not a drop in upgrade as you will (in addition to clearancing the rockers) need to check your valve geometry to make sure it's proper and if needed, cut custom length pushrods. Most foiks also add the solid
rocker spacers and heavy duty rocker studs at the time of the upgrade. |
Cap'n Krusty |
May 27 2014, 11:26 PM
The 911 swivel foot adjusters are definitely not a drop in upgrade as you will (in addition to clearancing the rockers) need to check your valve geometry to make sure it's proper and if needed, cut custom length pushrods. Most foiks also add the solid rocker spacers and heavy duty rocker studs at the time of the upgrade. There's that word again. Please explain, in your own words, what makes installing 911 valve adjuster screws an "upgrade". Use valid arguments. Make me a believer. If you use the word "everybody", please list their names and qualifications. This is an open book test. The Cap'n |
Java2570 |
May 28 2014, 07:22 AM
The 911 swivel foot adjusters are definitely not a drop in upgrade as you will (in addition to clearancing the rockers) need to check your valve geometry to make sure it's proper and if needed, cut custom length pushrods. Most foiks also add the solid rocker spacers and heavy duty rocker studs at the time of the upgrade. There's that word again. Please explain, in your own words, what makes installing 911 valve adjuster screws an "upgrade". Use valid arguments. Make me a believer. If you use the word "everybody", please list their names and qualifications. This is an open book test. The Cap'n Cap'n - I was trying to say they were NOT an upgrade and I do agree with you. And that is why I used stock adjusters when I rebuilt my stock 2.0L last year. I just didn't word my comments very well....nothing else to see here! |
Lo-Fi Version | Time is now: 8th June 2024 - 10:10 AM |
