Worried about high oil temps?, and/or low oil pressure? |
ChrisFoley |
May 28 2014, 05:21 PM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
A combination of high oil temp and low pressure seems to plague lots of 914 owners.
Engine modifications for more power often exacerbate the problem. Discussions frequently circle around the function of the primary pressure relief built into the crankcase near the oil filter. One member described how he reamed the bore and made a new piston, which seems to have solved his low pressure. I milled away a portion of a crankcase to have a better look inside the pressure relief circuit. What I found was significant wear, and evidence that the pressure relief was allowing oil to bypass the cooler most of the time. My newest product is designed to solve this problem. This little cylinder replaces the stock pressure relief piston and spring in the crankcase. Primarily what it does is eliminate the oil cooler bypass so the oil goes thru the cooler all the time. The precisely machined assembly will only allow oil above the preset peak pressure to bypass directly to the sump. It's also easy to change the max pressure by altering the piston length. Three prototypes have been made for testing. We installed the first one in a customer's 2.5L street/track car this afternoon. In the short time we ran the engine, improved oil pressure was immediately evident. Further tests will be done to see the effect on oil temp, but we aren't having hot weather here yet. The other two prototypes are being sent to people in warmer climates with competition cars, ready to put them to the test. I expect the benefit to be quickly apparent. (IMG:style_emoticons/default/smile.gif) |
boxsterfan |
May 28 2014, 10:48 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I would be very interested is this works well. Are you waiting for it to "prove" itself on a few test cases before making more?
Besides getting rid of the spring, any difference between this and the Weltmeister Oil Pressure Booster Kit? Easier install for sure as you don't have to mess around cutting the spring. The whole oil pressure relief setup is the last thing on my list to get "fixed" to help my oil temps (without going external cooler). |
ChrisFoley |
May 28 2014, 11:22 PM
I would be very interested is this works well. Are you waiting for it to "prove" itself on a few test cases before making more? Besides getting rid of the spring, any difference between this and the Weltmeister Oil Pressure Booster Kit? Easier install for sure as you don't have to mess around cutting the spring. The whole oil pressure relief setup is the last thing on my list to get "fixed" to help my oil temps (without going external cooler). I want some operating data before starting a production run. They may be available as soon as July. The Weltmeister kit still allows oil to bypass the cooler at relatively low oil pressures, and it doesn't solve the problem of wear inside the aluminum piston bore causing lower operating pressures across the entire rpm range. My assembly completely blocks the cooler bypass circuit, and is designed to stop leakage past the piston. Since the sleeve is steel, it will wear much more slowly. Preliminary cost projection is around $75. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:13 PM |
