Phoenx trip, high temperatures |
cpavlenko |
Jun 5 2014, 06:13 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Well, I'm driving my stock 71 1.7 from north AZ. To south Phoenix, and it's going to 108, or higher. My concern is heat and my engine. Never drove it with this type of hot weather. Should I have any concerns . (IMG:style_emoticons/default/confused24.gif)
Mblizzard |
Jun 6 2014, 01:13 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
You could also get a cheap flat electric fan for radiators and mount it temporarily with zip ties to the deck lid after you take off the rain tray. I got one off Amazon for abbot $20.
Dynasty 7 Inch High Performance Blue Electric Radiator Cooling Fan Assembly Kit. 1730 CFM. Slightly generous on the rating but moves a lot of air. |
Kansas 914 |
Jun 6 2014, 02:19 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
You could also get a cheap flat electric fan for radiators and mount it temporarily with zip ties to the deck lid after you take off the rain tray. I got one off Amazon for abbot $20. Dynasty 7 Inch High Performance Blue Electric Radiator Cooling Fan Assembly Kit. 1730 CFM. Slightly generous on the rating but moves a lot of air. Mike - Are you pulling air out of the engine bay with it mounted to the deck lid or the other way around - trying to blow outside cooler air across the engine? |
Mblizzard |
Jun 6 2014, 02:26 PM
You could also get a cheap flat electric fan for radiators and mount it temporarily with zip ties to the deck lid after you take off the rain tray. I got one off Amazon for abbot $20. Dynasty 7 Inch High Performance Blue Electric Radiator Cooling Fan Assembly Kit. 1730 CFM. Slightly generous on the rating but moves a lot of air. Mike - Are you pulling air out of the engine bay with it mounted to the deck lid or the other way around? It is impossible to overcome the force of the impeller at highway speeds. So if you anticipating mostly highway I would blow in. At idle you could see some benefit in pulling air out but not much. The actual impact of something like this won't be huge but it can help. |
Kansas 914 |
Jun 6 2014, 02:32 PM
It is impossible to overcome the force of the impeller at highway speeds. So if you anticipating mostly highway I would blow in. At idle you could see some benefit in pulling air out but not much. The actual impact of something like this won't be huge but it can help. Thanks Mike - that makes sense. I would only use it at speed - going up long grades where the temp tends to climb after about 10 minutes and still climbing. I usually grab a lower gear to increase RPM and likewise impeller speed but it doesn't always help. I probably wait too long and the engine becomes a big heat sink. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:05 PM |
