Ken6432 |
Newbie ![]() Group: Members Posts: 39 Joined: 10-March 14 From: Indianapolis, IN Member No.: 17,098 Region Association: None ![]() |
I have a '74 with a 2.2 L with dual carbs. I just swapped the engine and used all of the same accessories as the last (running) engine. Now that everything is bolted up, I am trying to crank the engine and nothing is happening. Here's what I have:
Both large wires connected to connector 30 Single wire connected to connector 50 Fully charged battery Voltage reading from connector 30 to the vehicle floorboard When I turn the key, I hear the electric fuel pump kick on then get one click and that is all. I tried connecting a remote starter switch between 30 and the other large connector and got nothing. I also connected the remote starter switch between 30 and 50 and got nothing. Any suggestions on where to look next? Is the starter bad? It worked fine before. Thanks, Ken |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Ground strap at transmission
Lo-Fi Version | Time is now: 16th June 2024 - 06:23 AM |
