Won't Crank, What are the possible issues? |
Ken6432 |
Jun 9 2014, 02:23 PM
Newbie Group: Members Posts: 39 Joined: 10-March 14 From: Indianapolis, IN Member No.: 17,098 Region Association: None |
I have a '74 with a 2.2 L with dual carbs. I just swapped the engine and used all of the same accessories as the last (running) engine. Now that everything is bolted up, I am trying to crank the engine and nothing is happening. Here's what I have:
Both large wires connected to connector 30 Single wire connected to connector 50 Fully charged battery Voltage reading from connector 30 to the vehicle floorboard When I turn the key, I hear the electric fuel pump kick on then get one click and that is all. I tried connecting a remote starter switch between 30 and the other large connector and got nothing. I also connected the remote starter switch between 30 and 50 and got nothing. Any suggestions on where to look next? Is the starter bad? It worked fine before. Thanks, Ken |
Chris H. |
Jun 9 2014, 02:49 PM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yep check the ground strap. Make sure it's reconnected tightly at the trans and the underside of the rear trunk.
Lo-Fi Version | Time is now: 16th June 2024 - 02:56 AM |
