| pda914 |
Jun 14 2014, 02:15 PM
Newbie ![]() Group: Members Posts: 40 Joined: 22-July 10 From: Verona WI Member No.: 11,966 Region Association: None |
I'm in the process of changing the ignistion switch. The start contact are burnd and do not ignite the starter motor. I have all the parts removed but the key assembly does not slide out. I have the keys in there and turned to release the wheel lock but I can not get it out. It seems that there is something that is holding it in place. It moves about a 1/32 in, and stops. Could the wheel lock not be fully disengaging? I put the steering wheel back on and it turns so it puzzles me on what is stopiong it.
Anyone have some advice on hwo to safely get the key assembly out so I can replace ths electical switch part? |
| hndyhrr |
Jun 15 2014, 10:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 670 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
as mentioned before pumpkin is a 70, here is a pic. tumbler assy is out and this is top of switch. notice the loop (lack of better description) well there is a screw that goes from tumbler assy into that (holds it all together) you have to pull on whole assy to get it far enough out to see screw. we had to unhook the electric and pull it all the way out of car what a pita. hope pic helps
pda914 touble changing ignition switch Jun 14 2014, 02:15 PM
pda914 please ignore my bad typing! Jun 14 2014, 02:15 PM
flash914 There should be a rule that states you must post w... Jun 14 2014, 07:31 PM
The Cabinetmaker No Gordon. It comes out the front. Jun 14 2014, 07:35 PM
orthobiz Ignition Switch
Pelican article...
Paul Jun 14 2014, 07:40 PM
pda914 I did follow this article in my attempt to get it ... Jun 15 2014, 09:54 AM
Dave_Darling 70-71 and 75+ are different from the article. Hop... Jun 14 2014, 08:55 PM
eyesright
70-71 and 75+ are different from the article. Ho... Jun 15 2014, 04:36 AM
SLITS '75 - '76 Electrical Portion Replacement Jun 15 2014, 08:12 AM
hndyhrr We had a heck of a time getting that out. Ended up... Jun 15 2014, 10:08 AM
hndyhrr [quote name='hndyhrr' date='Jun 15 201... Jun 15 2014, 10:09 AM
pda914 I had to pry the whole assemb;y off. If fit rathe... Jun 15 2014, 12:59 PM
JRust Post pictures of where you are at. Maybe you'v... Jun 15 2014, 10:19 AM
Chris H. And what year is it? Jun 15 2014, 10:20 AM
Kraftwerk I am about to dive into my electrical starter swit... Aug 15 2014, 06:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
