clutch pedal question |
hndyhrr |
Jun 15 2014, 12:02 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Lately when driving the car seems as if my feet are hitting each other when on the clutch and brake at the same time... funny my feet are not that big lol. I've attached a pic of what i found this morning when i went looking at the pedal assy. so my question is .... if i clip the bailing wire that the po put on there can i just slip the pedal off and clean it up find the right size roll pin and put it all back together or will i need to pull the whole assy? Was planning on re building it this coming winter, just want to drive the pumpkin now that it is nice out side.
thanks |
euro911 |
Jun 15 2014, 12:47 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Looks like the roll-pin is still in there (IMG:style_emoticons/default/confused24.gif)
You'll need to remove the whole pedal assembly, stick it in a vice and punch the roll pin out. Then the hard part - getting the arm off the shaft. They're usually rusted on. You may need to heat the arm up with a torch to expand it enough to pull it off the shaft. If going that far, you might as well install a new bronze bushing set too (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 11:03 AM |
