| ovilla |
Jun 18 2014, 01:05 PM
Member ![]() ![]() Group: Members Posts: 84 Joined: 25-February 05 From: Plainfield, IL Member No.: 3,660 |
I'm hoping that someone else with a 75 2.0 can chime in and tell me what is missing here. Is there a screw that fell out? Look at the pic, about an inch from the tip of the screwdriver in the pic. The engine will barely start and won't stay on. Its sputtering and wanting to die.
Thanks for your help! Attached thumbnail(s) |
| Java2570 |
Jun 18 2014, 02:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I just noticed your location is very near Peoria, IL....if you need a good shop, give Brad Mayeur a call
at 914LTD. |
ovilla What part fell of my engine? Jun 18 2014, 01:05 PM
The Cabinetmaker it hard to tell, but looks like the throttle cable... Jun 18 2014, 01:33 PM
Java2570 If you are pointing at that hole by the screwdrive... Jun 18 2014, 01:39 PM
ovilla Thanks for the feedback on the hole in the plenum.... Jun 18 2014, 01:48 PM
'73-914kid I'm gonna beat the cap'n to it.. get rid o... Jun 18 2014, 02:06 PM
Java2570 Definitely check all your components and if you ar... Jun 18 2014, 02:14 PM
Cap'n Krusty That vibration is likely a miss. First thing? Ge... Jun 18 2014, 02:39 PM
luskesq Adding to what the Cap'n suggested, confirm th... Jun 18 2014, 03:20 PM
ovilla I ended up doing two things to it yesterday, so le... Jun 22 2014, 02:03 PM
The Cabinetmaker No need to order ngk. Your local Napa or others c... Jun 22 2014, 02:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:16 PM |
