P/C Question, 1.8L to 2.0L |
jd74914 |
Aug 13 2004, 08:41 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I know this is a stupid question, but can i replace my 1.8L (93mm) cylinders with 2.0L (94mm) cylinders.
Is there any difference between the two. How much work would it take to make the engine accept the 2L cylinders? thanx for any imput |
Cap'n Krusty |
Aug 14 2004, 12:26 PM
Can't use bug pistons. Wrist pin diameter is waaaaaaaay different. You'd also need to work out the rod length (and the crank stroke) to accomodate the pin location of the pistons. Not the easy way .................. Best way would probably be to get a 76-79 bus crank and rods, then the 94 mm piston/cylinder set. Might want to consider the chamber volume in the equation while you're figuring this all out. The Cap'n
Lo-Fi Version | Time is now: 29th May 2024 - 02:06 AM |
