sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 969 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Installed Bilsteins and thought I was raising ride height but it did not,
For higher, where do I position lower spring perch spring I thought I knew what I was doing ( fatal character flaw) If it is already in correct position how can I increase height Thanks in advance for help Terry |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
The top groove will give you a very stiff, very hard, very rough ride. I run mine on the bottom groove for street use, and up one or two for track use
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
The top groove will give you a very stiff, very hard, very rough ride. I run mine on the bottom groove for street use, and up one or two for track use This makes no sense to me. The grooves adjust ride height not compression or rebound. If your ride comfort is changing, you shocks ma be bad or the dynamic between front and rear shocks is changing due to ride height. |
TheCabinetmaker |
The top groove will give you a very stiff, very hard, very rough ride. I run mine on the bottom groove for street use, and up one or two for track use This makes no sense to me. The grooves adjust ride height not compression or rebound. If your ride comfort is changing, you shocks ma be bad or the dynamic between front and rear shocks is changing due to ride height. I knew that was gonna draw a response. lol. Two year old bils all around. Shocks are good. Not an expert on dynamics, just my experience. |
Lo-Fi Version | Time is now: 3rd September 2025 - 02:35 AM |
