| swooshdave |
Jun 22 2014, 12:05 AM
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
I crawled under the car to check some things out. The major concern was the oil piddles on the ground.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403417122.1.jpg) The engine was mostly dry and the transmission was wet. But that could just mean it was coming back from the engine so after taking the picture I went to cleaning. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403417122.2.jpg) The right bank of engine had some oil on it. Are transmission leaks common? Maybe the pushrod tubes are leaking? |
| Mike Bellis |
Jun 22 2014, 01:25 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
My guess is the front main seal. Unless you drive backwards all the time. Then I would guess the rear stack gasket.
swooshdave Tracking down oil leak Jun 22 2014, 12:05 AM
76-914 Clean it well then let it run whilst parked. Drivi... Jun 22 2014, 07:18 AM
swooshdave
My guess is the front main seal. Unless you drive... Jun 22 2014, 02:11 PM
Mike Bellis Pretty easy fix but you have to pull the tranny. Jun 22 2014, 02:49 PM
The Cabinetmaker Is it oil or gear lube? Looks kinda green, unless ... Jun 22 2014, 04:39 PM
swooshdave I think it's the poor lighting. No idea what o... Jun 22 2014, 04:48 PM
dangrouche i had the same issue years ago; here is a pic of m... Jun 22 2014, 05:00 PM
Dr Evil Not (just) the tranny. That engine definitely has ... Jun 22 2014, 10:26 PM
swooshdave
Not (just) the tranny. That engine definitely has... Jun 22 2014, 11:33 PM
rhodyguy Start the PBblaster routine on your exhaust stud n... Jun 23 2014, 09:47 AM
swooshdave I'll hit them up but I do you need to pull the... Jun 23 2014, 08:42 PM
PlantMan
I'll hit them up but I do you need to pull th... Jun 24 2014, 02:02 PM
jacksun people have posted that they have changed the tube... Jun 24 2014, 07:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 02:42 PM |
