| swooshdave |
Jun 22 2014, 12:37 AM
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
This is my first time under the car (and the first time under a 914 or even a VW) so I could use a little help identifying some things.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.1.jpg) There is an unattached cable on the right side. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.2.jpg) There is also another unattached cable above the shifter. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.3.jpg) The car has an ANSA exhaust. I'm not sure if these two pieces are suppose to meet. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.4.jpg) I wonder if this hole should have something attached to it? |
| Dave_Darling |
Jun 22 2014, 09:40 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Some pics of the parts as they go together:
![]() ![]() ![]() A common patch for the rattling exchanger is a stainless steel hose clamp at the rear of the "wrapping". --DD |
swooshdave Undercarriage inspection Jun 22 2014, 12:37 AM
Mblizzard It looks like your heat system is pretty much miss... Jun 22 2014, 02:52 AM
bulitt Air circulates around your exhaust in a heat excha... Jun 22 2014, 05:04 AM
jacksun hi,
the following is a snip from pelican parts
... Jun 22 2014, 06:11 AM
76-914 Be sure your car still has the heat exchangers bef... Jun 22 2014, 07:08 AM
lsintampa first two pictures are cables that should attach t... Jun 22 2014, 08:44 AM
swooshdave Without the fan motors on I would think it would b... Jun 22 2014, 08:50 AM
malcolm2
Without the fan motors on I would think it would ... Jun 22 2014, 09:28 AM
swooshdave
My fan works, but the engine is running down the... Jun 22 2014, 11:35 AM
jmill
It's about the most convoluted path invented.... Jun 22 2014, 09:03 AM
cary That big tube in your last picture is the warm air... Jun 22 2014, 09:26 AM
swooshdave
That big tube in your last picture is the warm ai... Jun 22 2014, 10:25 AM
jacksun hi,
look at the diagram I posted before..
it lo... Jun 22 2014, 02:35 PM
swooshdave http://www.914world.com/bbs2/uploads_offsite/i237.... Jun 22 2014, 11:53 PM
Dave_Darling Part of what you outlined is the forward of the pi... Jun 23 2014, 01:49 AM
malcolm2 slightly off topic, but I need some pictures of th... Jun 23 2014, 01:32 PM
swooshdave
slightly off topic, but I need some pictures of t... Jun 23 2014, 08:47 PM
Dave_Darling There are two styles for the right side, and three... Jun 23 2014, 04:30 PM
GeorgeRud If you want to drive it without heat, you can use ... Jun 23 2014, 09:14 PM
swooshdave
If you want to drive it without heat, you can use... Jun 24 2014, 08:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 03:40 AM |
