> Undercarriage inspection, help me identify some things
swooshdave
post Jun 22 2014, 12:37 AM
This is my first time under the car (and the first time under a 914 or even a VW) so I could use a little help identifying some things.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.1.jpg)
There is an unattached cable on the right side.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.2.jpg)
There is also another unattached cable above the shifter.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.3.jpg)
The car has an ANSA exhaust. I'm not sure if these two pieces are suppose to meet.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403419060.4.jpg)
I wonder if this hole should have something attached to it?
GeorgeRud
post Jun 23 2014, 09:14 PM
If you want to drive it without heat, you can use a couple of spray paint lids and hose clamps to seal off the body connections until you can put the entire system back together.
swooshdave
post Jun 24 2014, 08:03 AM
QUOTE(GeorgeRud @ Jun 23 2014, 08:14 PM) *
Yeah, current plan is to drive around this summer and then pull the motor to do the seals that are leaking. No need for a heater.
swooshdave   Undercarriage inspection   Jun 22 2014, 12:37 AM
Mblizzard   It looks like your heat system is pretty much miss...   Jun 22 2014, 02:52 AM
bulitt   Air circulates around your exhaust in a heat excha...   Jun 22 2014, 05:04 AM
jacksun   hi, the following is a snip from pelican parts ...   Jun 22 2014, 06:11 AM
76-914   Be sure your car still has the heat exchangers bef...   Jun 22 2014, 07:08 AM
lsintampa   first two pictures are cables that should attach t...   Jun 22 2014, 08:44 AM
swooshdave   Without the fan motors on I would think it would b...   Jun 22 2014, 08:50 AM
malcolm2   Without the fan motors on I would think it would ...   Jun 22 2014, 09:28 AM
swooshdave   My fan works, but the engine is running down the...   Jun 22 2014, 11:35 AM
jmill   It's about the most convoluted path invented....   Jun 22 2014, 09:03 AM
cary   That big tube in your last picture is the warm air...   Jun 22 2014, 09:26 AM
swooshdave   That big tube in your last picture is the warm ai...   Jun 22 2014, 10:25 AM
jacksun   hi, look at the diagram I posted before.. it lo...   Jun 22 2014, 02:35 PM
Dave_Darling   Some pics of the parts as they go together: ...   Jun 22 2014, 09:40 PM
swooshdave   http://www.914world.com/bbs2/uploads_offsite/i237....   Jun 22 2014, 11:53 PM
Dave_Darling   Part of what you outlined is the forward of the pi...   Jun 23 2014, 01:49 AM
malcolm2   slightly off topic, but I need some pictures of th...   Jun 23 2014, 01:32 PM
swooshdave   slightly off topic, but I need some pictures of t...   Jun 23 2014, 08:47 PM
Dave_Darling   There are two styles for the right side, and three...   Jun 23 2014, 04:30 PM
GeorgeRud   If you want to drive it without heat, you can use ...   Jun 23 2014, 09:14 PM
swooshdave   If you want to drive it without heat, you can use...   Jun 24 2014, 08:03 AM
- Lo-Fi Version Time is now: 5th October 2026 - 03:40 AM
