clutch pedal question |
hndyhrr |
Jun 15 2014, 12:02 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Lately when driving the car seems as if my feet are hitting each other when on the clutch and brake at the same time... funny my feet are not that big lol. I've attached a pic of what i found this morning when i went looking at the pedal assy. so my question is .... if i clip the bailing wire that the po put on there can i just slip the pedal off and clean it up find the right size roll pin and put it all back together or will i need to pull the whole assy? Was planning on re building it this coming winter, just want to drive the pumpkin now that it is nice out side.
thanks |
toolguy |
Jun 26 2014, 08:59 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Does your pedal have the spring so that the pedal pulls down with no cable attached?? That's the way it is suppose to be. . . . Your picture shows the pedal in the fully upright position but I can't see if the cable is attached. .
Tightening the cable at the trans will pull the pedal up to where you have the top 1/2 inch play. At rest, the arm should be angled forward towards the engine when the T/O bearing makes first contact with the clutch. . {That's what the ball shim exercise was to adjust} If the trans end of the cable's 11mm nuts go too far down, add a metal thinwall pipe to extend where they sit on the cable Properly adjusted, you should feel resistance immediately when depressed. . If the cable is really too long, and you have excess play when depressing the pedal, this is a sign the bosen tube had broken lose, at the rear body bulkhead or in the body tunnel and is flexing under strain. |
hndyhrr |
Jun 27 2014, 10:19 AM
Does your pedal have the spring so that the pedal pulls down with no cable attached?? That's the way it is suppose to be. . . . Your picture shows the pedal in the fully upright position but I can't see if the cable is attached. . Tightening the cable at the trans will pull the pedal up to where you have the top 1/2 inch play. At rest, the arm should be angled forward towards the engine when the T/O bearing makes first contact with the clutch. . {That's what the ball shim exercise was to adjust} If the trans end of the cable's 11mm nuts go too far down, add a metal thinwall pipe to extend where they sit on the cable Properly adjusted, you should feel resistance immediately when depressed. . If the cable is really too long, and you have excess play when depressing the pedal, this is a sign the bosen tube had broken lose, at the rear body bulkhead or in the body tunnel and is flexing under strain. no cable attached in pic. |
bdstone914 |
Jun 27 2014, 11:08 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does your pedal have the spring so that the pedal pulls down with no cable attached?? That's the way it is suppose to be. . . . Your picture shows the pedal in the fully upright position but I can't see if the cable is attached. . Tightening the cable at the trans will pull the pedal up to where you have the top 1/2 inch play. At rest, the arm should be angled forward towards the engine when the T/O bearing makes first contact with the clutch. . {That's what the ball shim exercise was to adjust} If the trans end of the cable's 11mm nuts go too far down, add a metal thinwall pipe to extend where they sit on the cable Properly adjusted, you should feel resistance immediately when depressed. . If the cable is really too long, and you have excess play when depressing the pedal, this is a sign the bosen tube had broken lose, at the rear body bulkhead or in the body tunnel and is flexing under strain. no cable attached in pic. Was the lower clutch arm tight on the shaft ? It should be. If loose it puts all the stress on the roll pin which will eventually break. I can see the spring on the pedal set and the clutch pedal is in the depressed position as it should be. As suggested, adjust the cable at the trans end. Use an extra clutch fork yoke on the cable if you have one. It works better than the 11mm nuts. Bruce |
Lo-Fi Version | Time is now: 1st June 2024 - 12:43 PM |
