> is it possible ?, to install the axle with the spindle attached
hedgehog
post Jun 27 2014, 08:25 PM
i sheared the bolts that attach the cv joint to the spindle at the parade autocross...i assume they backed out slightly and when i was shifting into 3rd on a left hand sweeper...boom...that was it and i had to park it... took it apart and was hoping to wire tie it while it is out of the vehicle where it is easier to work on but getting it back in with the spindle attached is not working....any suggestions aside from dropping the motor....?
Cap'n Krusty
post Jun 27 2014, 09:45 PM
Cap'n Krusty
It can be done. Generally you have to remove the lower shock bolt, especially on the left side. BTW, we call that the "stub axle".
The Cap'n
hedgehog
post Jun 27 2014, 10:42 PM
QUOTE(Cap'n Krusty @ Jun 27 2014, 08:45 PM) *
The Cap'n
ya.... I already tried removing the shock bolt.... can't get the splines to line up...i even tried to pull them through with a piece of wire that i ran through the end of the "axle stub" (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 27th June 2026 - 08:11 AM
