| hedgehog |
Jun 27 2014, 08:25 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 6-June 06 From: Central Calif Member No.: 6,169 Region Association: Central California |
i sheared the bolts that attach the cv joint to the spindle at the parade autocross...i assume they backed out slightly and when i was shifting into 3rd on a left hand sweeper...boom...that was it and i had to park it... took it apart and was hoping to wire tie it while it is out of the vehicle where it is easier to work on but getting it back in with the spindle attached is not working....any suggestions aside from dropping the motor....?
| Cap'n Krusty |
Jun 27 2014, 11:23 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Oh, Ellyut! We love it when you're explicit .............................
The Cap'n |
hedgehog is it possible ? Jun 27 2014, 08:25 PM
stugray Yes it should be possible.
You should have enough ... Jun 27 2014, 09:28 PM
hedgehog
You should have enough... Jun 27 2014, 09:36 PM
Cap'n Krusty It can be done. Generally you have to remove the ... Jun 27 2014, 09:45 PM
hedgehog
It can be done. Generally you have to remove the... Jun 27 2014, 10:42 PM
76-914 :agree: It's a PITA. IIRC, I had to start one ... Jun 27 2014, 09:53 PM
Elliot Cannon While the car is on the ground loosen the large nu... Jun 27 2014, 10:42 PM
Mike Bellis I've done it a few times and is easy if you ge... Jun 28 2014, 07:51 AM
hedgehog
I've done it a few times and is easy if you g... Jun 28 2014, 10:16 AM
Mike Bellis
I've done it a few times and is easy if you ... Jun 28 2014, 01:13 PM
Elliot Cannon
[quote name='hedgehog' post='2055318' date='Jun 2... Jun 29 2014, 06:57 PM
Tom I just went thru putting mine back on my 76. I had... Jun 28 2014, 01:26 PM
stugray Or jack upwards on the trailing arm and go over th... Jun 28 2014, 03:06 PM
messix you didn't roll the car around with the stub a... Jun 28 2014, 10:07 PM
PotterPorsche Passenger side I just did , cv axle with stub. No ... Jun 29 2014, 08:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th June 2026 - 08:09 AM |
